Posted 15 May 2007 I have a open center valve that I turn off the extend sol. when it is in position. And when the process is done I need to turn the extend sol. back on. My problem is that when I do this the cylinder takes off at light speed (just joking) but it takes off fast. I would like to pulse the retract sol. to get air back in the cylinder and then turn on the extend sol. Has anyone done this before. ( I tried a closed center valve and I don't like the results I get from it) Help and Thanks Share this post Link to post Share on other sites
Posted 15 May 2007 I'm sorry to say that pulsing the valve won't help you out much when the power to the sol. drops out the valve will shift back to center and dump all the air back out. i would try a vavle that in the center position that p&t are blocked and a&b are tied togather Share this post Link to post Share on other sites
Posted 15 May 2007 how about a simple flow control? Share this post Link to post Share on other sites
Posted 15 May 2007 I agree. If you want to control the extend speed, this is the traditional way to do it. If you need full speed extend in some cases and a slow extend too, then a 2-way solenoid in parallel with the flow control should do the trick. Pick a NO or NC solenoid to suit your preferred failure mode. Share this post Link to post Share on other sites
Posted 16 May 2007 (edited) Something that could help is on this pneumatic cylinder meter the flow in the cylinder not out or a surge can occur. Thats my 2 cents. Edited 16 May 2007 by J&J Machinery Share this post Link to post Share on other sites
Posted 16 May 2007 i was taught that you always control the flow on the exhaust side Share this post Link to post Share on other sites
Posted 23 May 2007 i was taught that you always control the flow on the exhaust side Share this post Link to post Share on other sites
