Scadaman
Instant RJ45 serial cable
Dear Colleagues, RJ45 ports are be used as serial ports in modern PLC and Gateway alike. Yet the individual pinouts remain unique to each vendors. To meet this new challenge, Industran has patented and manufacture a adapter that let you make a CUSTOM RJ45 serial cable instantly without tools. This adapter is universal and will accomodate an infinite combination of pinouts. Check it out at http://rj485.com/index.php?main_page=produ...;products_id=49 Scadaman www.rj485.com Edited by Scadaman
for the RJ45/485 unit: There's an RJ45. And a plastic enclosure that covers a PC board with DIP switchs and what appears to be a green terminal block for the 485 copper wiring. How does the 485 copper wire cable get through the plastic cover? knockouts in the plastic cover? Custom drill the plastic cover for application? Ready-made hole through the PC card? What secures the 485 copper wire cable access to the unit? Dan
Dan, There is a opening for the 485 copper cable on the polycarbonate cover. The hole is big enought for 2 cables ( for of multi-drop or daisy-chain wiring ) The elevator type terminal blocks have screws to secure the 485 copper in place. Scadaman
