QUOTE(Ken Moore @ Dec 14 2006, 04:56 PM) [snapback]46233[/snapback]
Try setting up the hard drive with one partition of 7.8 gb or less, using NTFS and leave the rest as free unformatted space. Once the OS is installed, you can format the remaining space. Another thing to consider is RAM, I don't remember what NT's limit was, but try reducing to 1 gig or less and try the install.
Does this new motherboard have on-board video, audio, sound, network etc... You may have trouble getting drivers to support these inbuilt peripherals under NT4 - the hardware manufacturers (on the whole) are as anxious as Microsoft to kill NT4 off, by any means possible. that includes DELIBERATELY making sure that the newest hardware has no driver support. If you do find yourself in an 'unsupported' situation, your only option may be to disable the 'onboard' peripheral and add a plugin item in one of the PCI slots, or video in
the AGP slot - one for which NT4 drivers are available. Since this is a P4 you may also have to disable hyper-threading in the bios.
Yessssss!
Very useful answer to reality.
I have now solved my problem to install Windows NT on P4. I disabled all the extra features of motherboard (PM8M-V, MSI) including on-board VGA, sound, network etc.. I plugged an old versioned VGA card in PCI slot.
A lot of thanks are going to Ken Moore.
Naing
