Full Version: Accessing SLC5/03 via Ethernet?
TerryRWood
Hey guys...
I know I should be asking my AB rep about this but, Is there a way to access my SLC 5/03 from my office across Ethernet?
I've got about 70 or so PLCs with SLC 5/03 processors, none of them are linked together, but each PLC has a networked AB VersaView 1500 Industrial PC that is attached via serial comm. All my VersaViews are on my local network.
I know about the SLC processors with Ethernet ports, We use 5/05’s in our out of state satellite plants, I'm just looking for some creative alternatives to make local comms easier...
Thanks in advance
TRW
TWControls
If the Versaviews could communicate with the SLC5/03 through Ethernet then you could put a 1761-NET-ENI on the SLCs channel 0 to put it on Ethernet
It may also be possible to use some type of pass through or bridging through the Versaview but I have never used a Versaview
TerryRWood
QUOTE(TWControls @ Nov 30 2006, 10:59 AM) [snapback]44832[/snapback]
TW....
The Versaview is for all intents nothing but a PC with a Touchscreen, We us a program written in VB for all of our interface screens.
It communicates to the PLC via serial communications for Bit and Interger read/writes.
All I need is that bridge between the two... I have extra Comm ports on the Versaview that I could use to get to the DH485 port on the 5/03 with something like a PIC module in between, I'm just not that versed in DataHighway type communications.
The AB "NO"ledge base has a posted question refering to the 1761-NET-ENI....
Answer ID 37235
Can I connect a 1761-NET-ENI to a SLC processor and use passthru to communicate from ethernet to DH-485, DH+, or another ethernet network?
Question Can I connect a 1761-NET-ENI to a SLC processor and use passthru to communicate from ethernet to DH-485, DH+, or another ethernet network?
IPB Image Answer No, the 1761-NET-ENI does not support passthru capability.
TRW
TWControls
The Versaview has an Ethernet port, correct? It couldn't communicate with the SLC on Channel 0 through a 1761-NET-ENI through the Ethernet port?
TerryRWood
QUOTE(TWControls @ Nov 30 2006, 11:21 AM) [snapback]44835[/snapback]
We are using that Ethernet port to communcate to the network....
My hopes were to be able to daisychain my 5/03's via DH485 and attach some type of bridge device that I could see them in RSlinx across my LAN.
TRW
TWControls
I don't see why you couldn't communicate with your network and the SLC at the same time over Ethernet but I don't know your layout.
Controllogix chassis with a DH-485 module and a ENBT?
Smoke
QUOTE
We use to do what you are wanting. I cant give you any part numbers because we have since upgraded all those CPU's to 5/05's and gave each the own network connection and I don't remember what we used, but it can be done.
BobLfoot
QUOTE(TerryRWood @ Nov 30 2006, 10:54 AM) [snapback]44831[/snapback]
Hey guys...
Thanks in advance
TRW
So let's see If I get this. You have about 70 PLC Cells. Each cell has an SLC 5/03 connect via it serial port to a VersaView PC. Each Versaview PC is then connected to your plant network via ethernet. You have a PC in your office and want to connect to each SLC 5/03 if possible.
Plan A
Add RSLinx Gateway to each VersaView PC and then connect your local PC Rslinx thru the Gaetway Linx to The SLC 5/03. Cost is $2095 per unit.
Plan B
Use the DH-485 port on each SLC 5/03 and add a 1761-Net-Eni. Connect the ENI to your plant network. You now have your 5/03 accessible from your office. This assumes the DH-485 port is "free" and the Versaview is using the Serial port.
Plan C
Use the serial port on each SLC 5/03 and add a 1761-Net-Eni. Connect the ENI to your plant network. You now have your 5/03 accessible from your office. This assumes the serial port is "free" and the Versaview is using the DH-485 port.
Plan D
Break each serial or DH-485 connection and attach the SLC 5/03 to a 1761-Net-Eni. Connect the ENI to your plant network. Revise each Versaview program to read values over ethernet rather than serial./DH-485 You now have your 5/03 accessible from your office.
Ken Roach
Some of the options here depend on whether or not the local VersaView PC is running a custom DF1 serial driver or is running the RSLinx DF1 driver.
Networking 70 controllers that don't have an Ethernet port will necessarily cost a little money, whether in wire/conduit/labor or in hardware or software.
If it was cheap to run DH485 cable among all the SLC-5/03's and you already had 1747-AIC isolators in place at each station, I'd say go ahead and buy three or four 1747-UIC's and three or four copies of RSLinx Gateway. 70 stations / 4 = average 18 stations per network is pretty heavily loaded but tolerable for slow data collection, or for one-at-a-time online monitoring.
If you could get a good deal on qty. 70 of the 1747-UIC interfaces, you could try a Virtual or Network Serial Port connection. On the VersaView, the 1747-UIC would appear to be a COMx serial port, usually enumerating as COM3 or COM4. Run a Network Serial Port program like the one from FabulaTech, and that COM port could show up as another COMx on your office computer, allowing you to run a local copy of RSLinx. I have not tested this, but it doesn't violate any of the principles of DF1 networking.
rpraveenkum
My option is Go with Net-ENI interconnect all the SLC use RADmodem to connect to the Internet
