Thanks Guys... I think I'm going to opt for the $49 replacements and quit carring that brick around.
Terry
QUOTE(panic mode @ Nov 28 2006, 07:43 PM) [snapback]44654[/snapback]
what's wrong with it. i "repaired" few of them that had the flat cable damaged.
repar was basicaly:
- cut of the cable along box edge before opening it
- open box and throw away the cut piece of cable
- insert remaining part of the cable that was still with connector
- squeeze and close the box.
but this is as far as i would go (and i like to fix things).
this is old unit anyway, did you consider switching to UIC module?
Thanks Panic... I have the UIC but I'm still pissed at AB that they can't fix the error you get when burning to eeprom. I like my old faithful comm port communications. All the bad PICs I have give me a Communications error 00000005 in RSLINX. It could be loose wiring, you can get communication every once in a while. It's really odd, I've gone through 3 this month, it's like my car the day after the warranty ran out.
TRW
