Hi there:
We have a winder machine working with a controllogix controller , it uses a 8 axis Sercos interfase.
I'm very new using controllogix as most of PLC on the plant are SLC5 series so I"ll really thank you if you could help me with this problem.
The winder has 4 servos connected ,the problem is the second servo called "jumper" when machine is wiring this servo moves down a screw transmition assembly connected to a guide, it moves when the number of turns per coil are done so it moves down 3 times , on the third movement lifts the guide to its home position, the problem is that sometimes after third movement guide remains down and doesn't go up , we don't get any error messages on sercos interfase or amplifier module neither on PLC,so we turn off the machine and manually lift the guide, this problem happens randomly, it can be working a full shift and it doesn't fail.
I was reading that there is a way to send motion commands from Rslogix 5000 but as I said I'm new with controllogix and also this machine is within an enclosure and there are several pieces near servo.
We have checked mechanical transmition assembly connected to servo and this is ok we don't have slips
Any way to determine if servo is ok?
Thanks in advance.
Gabriel
