We have some machinery using 5/03 units, these connect via 9pin port to aic units, which in turn connect to hmi and remote programming port /9pin d. the port setting is dh485 .
With our older laptops, we used to connect to the remote programming plug with ab cable cp3 from com 1 on laptop.using the pic driver.
Since getting newer laptops on xp, there is no option of pic driver what do I select to connect via com 1?
I can connect to rj45 port on 5/03 using usb adaptor ,but would like to know how to connect to 5/o3 units 9 pin plugs where they are set as 485 rather than df1 full duplex. what driver and settings should I be using
thanks
