I am using a SLC500 processor with a 1747-SDN Devicenet Scanner. I have over 30 nodes on the Devicenet network. Each of the nodes consists of the the same hardware device, a westlock controls d-pack. The d-packs are operating ballast control valves on a C1D1 rated barge. There is no room for errors on this vessel.
Anyway.... here lies my dilema. Everything works, but when a node drops offline (say for maintenance) the HMI still shows the last known state. The operator never sees a change on that device even though its inoperable. I need to find out how to map individual comm status bits for each of the devicenet nodes. This way the operator can pinpoint exactly which node drops offline. I know the info is available in the scanner for the simple fact that it displays it on the eight segment leds on the scanner itself.
Currently, the system flags a common alarm for when any node drops, then the operator has to open the PLC Cabinet, find the scanner error code, look it up, find which valve is associated with that node address, then find the drawing to find which valve has the address, then go trouble shoot that valve. These operators are not that fluent with this type of troubleshooting, and I must agree that it is cumbersome.
Please help... thanks...
