Full Version: How do I set up a Micrologix 1100?
The Turkey Slayer
I'm new to this module.
I have it hooked up to the ethernet switch by my desk. When I try to find it in RSLinx it doesn't show up. The ethernet address setup in the processor is blank. I have no idea how to set one up so it can be recognized on my network.
TWControls
It can be set by the display. That or the serial port will be the quickest way. Otherwise you need a bootp or dhcp server
BobLfoot
QUOTE(TWControls @ Nov 20 2006, 05:54 PM) [snapback]44010[/snapback]
TW fails to mention that the Rockwell BootP server ships with RSlinx / RSlogix.
The Turkey Slayer
How do you do this? I'm pushing buttons and can't figure it out.
BobLfoot
QUOTE(The Turkey Slayer @ Nov 21 2006, 08:18 AM) [snapback]44074[/snapback]
Try Page 5-34 and following of the User Manual for 1100.
rpraveenkum
See this article for more Ifo about Ml1100
http://www.mrplc.com/kb/index.php?page=ind...;id=76&c=29
finfin
TWControls said that the ethernet address can be set by the controls and later to check 5-34 of the user manual. The heading when I go there is "Viewing Ethernet Port Configuration"... nothing about setting. If there is really a way to do this I would love it. Especially since the memory module for this will not configure the ethernet port. This leaves my customer with no way of downloading a program in case of a processor failure that corrupts the IP address or otherwise causes the processor to be replaced.
TWControls
Can't do it. I don't know where I came up with that idea.
BootP is the quickest way.
Sorry for the confusion
