bullet
Nov 19 2006, 10:59 PM
I'm using RSnetworx V5.00 communicating with Reliance drive GV6000.
I can use logic command and logic reference to stop /stop /jog the drive, and get the logic status feedback through M0/M1 file mapping. The 1747-SDN scanner is at address "0", the GV6000 address is "2". However, in the RSnetworx screen, when I go to "parameters" of GV6000, all parameters are showing "error". I'm wondering why this could happen, it 's supposed to view and change the parameters online. Anything that I've missed for setup ?
Attached picture is I captured offline, but it's the same with online.
jstolaruk
Nov 19 2006, 11:03 PM
Correct EDS file?
I'm using v6.0 and there is a newer version available, can you get upgraded?
bullet
Nov 21 2006, 03:36 AM
Is it related to RSNetworx version?
But I can stop/stop/jog the drive using mapping of 1747-SDN, and format explicit message to view/edit the parameters. Only thing is on the RSNetwrox, I cannot view/edit the parameters of the subject GV6000 drive .
rpraveenkum
Nov 21 2006, 04:07 AM
Any Error Message you are getting at the bottom . Any device ADD or Minus or not matched symbol is displaying in the layout of rs networx
what error message you are getting in the Bottom of the application You can post the code in this thread
bullet
Nov 22 2006, 04:06 AM
Once using RSNetworx going online, the VFD has a fault" DIP Fault", and RSNetworx diagnostic showing :
Fault: address 03 ,xxxx (drive name)identity /instance 01/Major Recoverable Fault.
Once I clear the fault at the VFD panel, RSNetworx says the subject drive return normal.
Attached picture is the fault captured.
BTW, I can start /stop the VFD using explicit message, the problem is:
After I press start (acually toggle the start bit), I can see the feedback from the drive is "active", then I press and hold "jog", the VFD panel shows"at speed", but no herz output, it seems the drive is waiting for command like frequency reference or RPM reference. Anyone could help me ? I'll post my program here.
rpraveenkum
Nov 22 2006, 04:58 AM
QUOTE(bullet @ Nov 20 2006, 08:59 AM) [snapback]43927[/snapback]
you have told GV6000 address is 2 but error messages shows address as 3 what is node adderss of PC?
bullet
Nov 22 2006, 09:49 PM
I'm having two VFDs , address 02, 03.
Same problem happened on both VFDs.
rpraveenkum
Nov 22 2006, 11:09 PM
QUOTE(bullet @ Nov 23 2006, 07:49 AM) [snapback]44242[/snapback]
bullet
1747-PCD address 05
1747-SDN 00
GV6000 02, 03
By the way, how to issue a speed command using explicit msg?
Like I just simple enter 50HZ, then the drive will command at 50HZ? Sorry this question is too simple. I've done this way:
Set the "JOG SPEED" to 50HZ, then issue a JOG command thru M0 file, but that should not be the correct way, right?
click here.
