QUOTE(IO_Rack @ Oct 18 2006, 01:10 PM) [snapback]41834[/snapback]
OK.... I think I answered my own question again.
You can't exacly change the backlight color property directly. But you can create multiple screens each with thier own color. So if you want to change the backlight only, you can create two identical screens with different backlight colors then just switch screens with the PLC.
I think. [scratchin' the head smily]
Sure you can. Look under the Setup -> PLC to Panel menu. Go to the PLC->Panel tab and there is a place for a setup word. If you use V2000 as the starting setup word, the screen color word will be V2002 .
