QUOTE(tunnysting @ Oct 16 2006, 11:06 PM) [snapback]41760[/snapback]
Hi,
just wondering if you can calibrate a Hardy HI 200DNWM using logix5000 code and an HMI screen instead of having to do it over RSNetworx? If anyone has i'd love to hear.
Thanks
I am assuming that your Hardy HI 200DNWM is a devicenet implementation or a hardy scale. That being the case you should be able to use explicit messages and plc code to calibrate it as you describe. May be more headache than you want to take on. But should be doable.
