QUOTE(rogeliososa @ Sep 6 2006, 06:28 PM) [snapback]39779[/snapback]
Hello,
I am trying to link one HMI CTC from parker with a Koyo PLC DL205 cpu 260. The ctc has the driver:
Siemens/koyo/205/305/405. I can configure this driver with the port, baud rate,etc. The PLC DL205 is using the protocol Ksequence and I am trying and trying changing baud rate, parity, etc. and I do not get sucess.
Can somebody share me a technical tip????
thanks a lot.
The only thing I can think of, without getting into details, is this:
If you are using the programming port then connect your laptop to the koyo plc and using the programming software, from Automationdirect.com, try to connect to it. The software will search for the correct baud rate, etc. Once the setting are found use those settings in your HMI.
