Hello all,
I just got a call from work about a problem they are having with a printer. We have a Primus Sterilizer that has a SLC 5/04 connected to a PanelView 1000, and it has a ribbon style printer hooked up to the PanelView. Here is the issue. The Sterilizer fucntions normally mechanically, and the SLC seems to work fine, Cycles parameters, values and setpoints all function normally on the PanelView. However as its going through its functional sequence it is supposed to print out all the parameters and values for that particular cycle, and continues on to the next one. The problem is that the printer is not printing all the cycles, and not all the parameters and values. Kinda makes me think that I have a corrupted RSLogix 500 file in the CPU or in the PanelView. I'm thinking that all I should have to do is Download the RSLogix 500 file to the SLC, and try that. Are the "to print" files located in the PanelView. I need some input.
Thanks
John B.
