The PV using DH-485 should show up in Rslinx.
I am using RSlinx v2.5 Lite.
I am using a PCMK card with DH-485 cable. (Using thePCMK driver)
I can see the PV in Rslinx no problem. (Make sure that you boot pressing the right-hand bottom corner) otherwise, without a program, it is in ERROR, and will not communicate.
I am testing one as we speak, and all is well.
I will test with a PIC if you want.
QUOTE(CCSI guy @ Aug 10 2006, 12:38 PM) [snapback]38070[/snapback]
I've got to get a spare PanelView 600 out to be installed, and I'd like to put the application on the panel before I send it out, because my company doesn't have a lot of people who can do it in the field. The PanelView doesn't have RS232, though, only DH485. I'm having a hard time firguring out how to get RSWho to see the PanelView.
I found a 1747-PIC and downloaded the latest driver and followed the bulletins and stuff. So I think that part should be OK. I added the PIC to RSLinx, but it doesn't see the PV.
Then I read on the forums that the PIC doesn't play with PanelView because it still needs 24VDC from somewhere. This seems a little odd, because I've got the PanelView powered up, so you'd think there would be 24V somewhere... but there's not.
Option 1)
One solution, from what I have read, would be to buy a 1747-AIC, which would provide the 24V power up the DH485. Can anybody confirm that this solution works? But, naturally, I was really hoping to avoid spending any money.
Option 2)
Would it be OK just to take a spare connector and wire up the 3/8 and 4/7 pins to the same 24V supply that's powering up the PanelView? I've already let the magic smoke out of another device recently, so I really don't want to smoke this PanelView. Plus then I'd spend a lot more $$ replacing the PV than I would have by buying the AIC in the first place.
Option 3)
Rather than running through the PV, I could just hack into the PIC's cable and put the 24V right there. That's probably better than #2. Does anybody know if that would work?
Option 4)
Can I use the 1747-UIC? Does it actually work? I have had bad luck with USB converters in the past not working well, so I didn't want to go spend money on one just to find out it doesn't work. The best part about the UIC is that I could finally put the older laptop (the one with a real serial port) to rest and just use my normal laptop (with no serial port).
Cannot see with the PIC box.
(1747-PIC)
QUOTE(snk @ Aug 10 2006, 02:00 PM) [snapback]38074[/snapback]
Option 1)
Option 2)
Option 3)
Option 4)
