In fact there are two 16-bit pad
words on the Input connection of a Generic Module on ControlNet.
I think the contain the some connection status data, but I have always simply ignored them. A 6-byte (3 word) Input and 4-byte (2-word) I/O connection to a 1203-CN1 will not work.
For the simplest Coimmand/Reference and Status/Feedback connections to a 1336F drive with a 1203-CN1, the I/O connection should be 4 Words Input / 2 Words Output. Ignore the first two words.
Fortunately you don't need to know that, or use a UDT, for an A-B drive on ControlNet or EtherNet/IP with ControlLogix. The drives have been available as I/O devices with automatically-created Controller-scope tags with descriptive tag member names since at least v13.
To see the old way it was done, see Knowbase document
G18310. For the new way, just select a drive as an I/O device on ControlNet or EtherNet/IP.
And wait until you see the drive configuration data automatic integration in v16 !
