QUOTE(wrenchforhire @ Jul 25 2006, 01:54 PM) [snapback]37255[/snapback]
Can anyone tell me the part number for an Allen Bradley cable to connect RS232 to 8 pin mini DIN, or if there is an adapter available?
Or is there another way to talk to a SLC500 with a panelview installed? Not ethernet
Thanks
I would be careful if I were you. Based on the limited information given, I believe you may have a SLC 5/04 PLC, it's the only SLC model I can think of that has a mini DIN connector. On the 5/04, the mini DIN connector is for DH+ (Data Highway Plus) communications, it is not a serial connection. AB sells products that allow laptops and desktops to connect to DH+ networks, but they are expensive.
If your application allows, the cheapest solution is to disconnect the panelview and use the RS-232 port for PLC access. It will most likely be configured for DF1 or DH485.
