Hi Gentlemen, ask if you realized Connection
among PanelView Plus with a PLC Siemens S7 in Ethernet, the KepServer using Ethernet
to the PanelView.
I premise that Making a will the PC Project in Simulation with the KepServer
Enterprise V4.0 works.
However then when I transfer the lines compiled to the PanelView, it doesn't
work me.
The Firmware Installed on the PanelView is the Version V4.06 (I have Installed
the Options S7-TCP/IP for the KepServer) and I have adjourned the to Sign.
I have Already tried the same configuration in MPI (+Adapter RS232/MPI) with
success however the
Ethernet doesn't work.
Can you help me?
Thanks.
