Full Version: CXsupervisor problem
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Supervisor
banker
Hi
I have been upgrading my CXsupervisor to ver. 1.3 (from 1.22) and now I got a new problem I have not seen before.
I Have some text point that contain time stamp. eg. 12:10
I transfere this textpoint point to Excel Via DDE poke. But in Excel 12:10:22 change to 12:01.
I have tryed to change format in excel but nothing helps me.
Banker
Zoran Mihajlovic
If you dont't need this for later work as time ,you can test that point in CX-Supervisor is text point and then
too use it for transfer in Excel in cell that is defined as text.
banker
Thanks
The problem is in the CXSupervisor V1.3 it works in all my other programs with older versions (1.22)
I have got at update/fix from Omron for this problem same with a fix for the problem with the Logviewer V1.8
tashinz
Hi
it would be great if you could post here those fixes?
Best regards
tashinz
Banker
is there a possibility to post here the patches?
Many thanks
PdL
QUOTE(tashinz @ Jul 26 2006, 03:49 PM) [snapback]37307[/snapback]
Banker
Many thanks
On behalf of Omron UK:
QUOTE
Yes there are test builds for these issues sent to reporting customers to
confirm fixes. These test builds are untested and unmanaged and it is
preferred they are not distributed in an uncontrolled manner as this may
actually create further problems in the future. The fixes will
automatically be included in the next formal release, available for free to
registered users from the Omron Software Download site. However, anyone
suffering the same symptoms can contact their Omron support channel and
these test builds would be supplied in a controlled manner to also confirm
the fix.
I understand their point of view now it's been confirmed as untested. They are probably working together with the customers to get the patch tested and bug free and then it wil be included in the next public release.
Tashinz, please try to contact your local Omron rep to obtain the patch.
tashinz
The problem is I work for local Omron rep in Serbia, Mikro Kontrol. So, I will then contact Omron Europe.
Hope they could send me those fixes.
Many thanks PdL for your effort.
Andrey Zhuk
In DataLogViewer. OCX (1.8.0.6 and 1.8.0.7) "Language setting" does not work.
In DataLogViewer. OCX (1.7.0.0) " Language setting " works.
tashinz
I have the same version (1.8.0.7) and it works in an application with english, russian and serbian (mine translation). if I set language in SCADA it reflects when I open data log viewer window and also if i set the language from data log viewer window.
This new datalogivewer.ocx is really bugy though, had problem with session file.
