moltra
May 26 2006, 11:40 AM
I am trying to figure out how to connect to a controllogic plc at ip address 191.168.101.1 255.255.255.0 when the IT lan is on 192.168.100.x 255.255.255.0. I know I can change my computers IP address to 192.168.101.15 and connect no problem when I am physically connected to the IT LAN.
What I need to be able to do is connect to the PLC when I am out of town or not physically at the plant.
I can connect to the company LAN via Check Point SecuRemote Service software via the internet. What I need to know is how to connect to the PLC throught this connection or any other way that might be easier.
I would appreciate any and all help with this.
TechJunki
May 26 2006, 11:52 AM
The way I normally do this is to leave my computer IP on the Office Lan, then go under advanced TCP/IP settings and add another IP using the add button, this will then broadcast that ip into another network allowing you to connect to other devices.
EDIT-- your IP addresses will be where the black boxes are, I created the boxes to erase my ip's from view... for obvious reasons.
TWControls
May 26 2006, 12:58 PM
I use a router to bridge the two networks.
You should not have the a PLC hooked to the office network. PLCs don't like multicast packets among other things. PCs don't like the constant polling that PLCs do. This can really become a problem when bandwidth is an issue
moltra
May 26 2006, 03:51 PM
Any idea how I can connect when I am not in the plant?
TWControls
May 26 2006, 04:37 PM
You say you can connect to the Office network from offsite. Is that correct? From there setup the router to route from the office network to the plant network
moltra
May 27 2006, 09:42 PM
[quote name='TWControls' date='May 26 2006, 05:37 PM' post='34648'] You say you can connect to the Office network from offsite. Is that correct? From there setup the router to route from the office network to the plant network [/quote
I connect via a VPN client and was told by RA that most of them do not open the correct ports. Any info?
Snerkel
May 28 2006, 04:38 AM
We have a programming PC setup with remote desktop (Windows XP pro). We then use remote desktop from anywhere to access the PC and do any software mods/monitoring.
We have used VNC but remote desktop is so much quicker, and is just like being sat at the PC.
Bob O
May 28 2006, 06:35 AM
I am doing the same thing as snorkel.
I have a server at work with XP pro and remote desktop that I can access from home or across the country.
A couple of weeks ago while taking Ron’s course I need to get access and I was able to use the hotels wireless network and my laptop.
I second the opinion that remote desktop is much faster then VPN.
Hope this helps,
Bob
moltra
May 28 2006, 02:11 PM
To do that do you need two copys of RSLogix 5000?
QUOTE(Bob O @ May 28 2006, 07:35 AM) [snapback]34715[/snapback]
A couple of weeks ago while taking Ron's course I need to get access and I was able to use the hotels wireless network and my laptop.
Hope this helps,
Bob
Bob O
May 28 2006, 03:15 PM
No.
When you connect through remote desktop you are actually on the computer you are connecting to so you will be using the software on that computer. Therefore, RSLogix5000 would have to be installed on the computer you are connecting to, not on the one you are using to dial in with. Clear as mud?
A side note is that I have not been able to start RSLogix500 using remote desktop [I get an error] but that has not been an issue with me since I keep it running in the tool bar. I think I could find out why I cannot but at this time, it is not an issue with me.
Hope this helps,
Bob
rpraveenkum
Jan 19 2007, 05:27 AM
QUOTE
Hope this helps,
Bob
how about security access to PLC how it will done
Bob O
Jan 19 2007, 06:31 AM
Not sure how IT has that set-up.
My guess would be they don’t have it set-up too secure but we have never had any issues and it is more reliable then a lot of other stuff they do.
click here.
