QUOTE(capi @ May 25 2006, 08:49 PM) [snapback]34572[/snapback]
Hi, I'm wondering if you can help me with this problem.
I need to pull out from my DL06 PLC some registers once a day and I don't know if I need to purchase an ethernet module or I can do it with the programing port.
I found a modbus-TCP/IP module that can communicate via ethernet but I need some kind of control to establish the communication, the DDE, I think so.
I also have an eztouch panel connected to the plc, so, maybe I could access thru there.
The issue is that I need it to be not too much expensive
I hope you can help me, I will appreciate that.
If you want cheap and are only collecting a handful of values then:
You can use the programming port with an rs232 cable, then communicate using the dde-server and something like excel or a vb program, etc. I also think one of the serial ports can communicate using modbus RTU, but i can't remember check the manual.
Otherwise if you want speed and/or have the PLC on a plant network then an ECOM module would be nice. You can use Modbus TCP with that, or the opc server, or the dde server, or something like Dataworx.
