QUOTE(vanilla_gorilla @ May 22 2006, 07:22 AM) [snapback]34344[/snapback]
QUOTE(Bob O @ May 22 2006, 06:45 AM) [snapback]34338[/snapback]
I have not done what you are asking using the AWT but I will try to help with the creating of the String [ST] file. You need to create the ST file first by right clicking on Data file -> New -> type -> String and then enter how many elements you would like.
Hope this helps,
Bob O.
Yep that helps, its a start.......!
I did this many years ago, and I remember having trouble figuring out how to load the data in the ST file. I remember having to use the "^" symbol and the "/" symbol and it seemed that a certain keystroke combination was required to get them to appear in the data table. I wish I could remember more about my struggles with the RSLogix5 editor...
Every time I've done serial communications, it's amounted to a lot of trial and error to get everything set up right. Pay very close attention to all the settings for CH0 and compare with the receiving device requirements. Often you have to translate terminology differences between manufacturers.
You can use AWA to simplify the data tables if your receiving device(s) require a termination character that is consistent.
Hope this helps...
