I am in the process of retrofitting a 4 post 500 ton hydraulic press with a new control system. I have read the OSHA standard for press controls which states if using a PLC for press control it has to be a redundent processor system. It also goes on to say that hydraulic presses are exempt from such requirements but doesn't say much else on the subject and OSHA requirements read like a mud cake recipe. I am planning on using a SLC 5/05 and panelview 550 as the main control and LDT's as ram and cushion position sensors. Several press control manufacturers have been contacted for the safety requirements and the ones that make dual processor controls (Including Allen Bradley) have told me that dual processors are Recomended but won't come right out and say that 2 processors are not absolutely needed. I will have all the usual safety equipment such as light curtains, anti-tie down two hand controls, gate interlock switches, and probably safety feedback relays. Did I miss anything in my reading or can someone show me what else is ABSOLUTELY REQUIRED.
Thanks
