navillusi
Aug 1 2003, 09:21 AM
I need a solution for a current RSView project to integrate an instantaneous flow into a cumulative flow total.
The instantaneous flow is derived from a device tag in litres per second.
I would like to integrate this into a total flow periodically, e.g. every minute.
At the end of the day the total is moved to "storage" tag and then reset to zero.
I had the idea of running an event every minute and using derived tags to do the math. It seems somewhat long winded.
Does anyone know of a simpler solution, perhaps using VB?
(There are no reporting add-ins or other extra's on this system)
Cheers
PhilipW
Aug 2 2003, 02:12 AM
Hi,
The file I posted called "Small Pumping Station Example using subroutines" includes a flow totaliser routine that does exactly what you are asking for, but in the SLC rather than RSView.
I realise you may have a reason to do the totalising in RSView, but in most cases I would plump to do it in the PLC because there is less risk of loosing the totals and I think its easier to do.
On the other hand if someone else has a nifty VB app that does this task already, then let us all know!!
Roth
May 2 2007, 02:44 PM
Unable to find your post "Small Pumping Station Example using subroutines" can you advise where to get as i would like a look at totaliser code.
