lchamarthi
Apr 7 2006, 03:09 AM
Hi Everyone!
Hello TWC controls! I understood the MVM instruction usage as u mentioned in the sample program & instruction help in RS Logix.
Example is like this!
Also example given in Help is
If we see help example, 0000 are to be masked ones then how 1111 came in result value_b. I think masked bits output should be 0000
After clearing this basic question (above image), please clarify me in the/co relate first picture how it will manipulate?
One more silly question, Is RSLogix 5000 software is enough to communicate from PC to PLC otherwise i need to have RSLinx Software as mentioned earlier & if then programming recommended cable?
Thanks in advance.
Lchamarthi
BobLfoot
Apr 7 2006, 03:22 AM
For whatever reason when I viewed your post the images did not come through. So I'll answer the part of your post I can. RSLogix 5000 software lets you create the program but to get it to the processor you will need RSlinx and a programming cable. If you purchased RS5000 it comes with a free copy of RSlinx Lite. you'll also need either an ethernet cable if using a 1756-enet ot enbt module or a serial cable to communicate with the plc.
You might find these links useful.
[url="http://literature.rockwellautomation.com/idc/groups/public/documents/webassets/browse_category.hcst"]Rockwell Automation Literature Library
[/url]
[url="http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/$$Search?OpenForm"]Rockwell Automation Knowledgebase
[/url]
I'd start at the literature library and do a search by catalog number for 1756 the general family number for the Controllogix.
TWControls
Apr 7 2006, 05:27 AM
lchamarthi - Can you answer my last question on THIS topic 1st? I understand and respect your right to confidentiality. But the sake of our sanity, don't start another topic such as this on when it was building on the previous topic. In fact, since you images did not work, why don't you repost this in the previous thread. You only need to start a new thread if you are going to something completely different or we get way off topic. The main reason we ask this is the first thing you mention is my sample program. It won't be long till someone post the question "What sample program?"
lchamarthi
Apr 7 2006, 05:53 AM
QUOTE(TWControls @ Apr 7 2006, 05:27 AM) [snapback]31456[/snapback]
Hello TWC Controls, I understood the situation. As i thought it should not exist to smothen the things to my side.Next time i won't delete. Sorry for this time to everybody.
Regards
Lakshmi
lchamarthi
Apr 9 2006, 11:04 PM
Could anybody offer me help in understanding above MVM instruction query please?
Thanks in advance
Lchamarthi
TWControls
Apr 10 2006, 05:38 AM
Lchamarthi - We can't see your images so your question is not clear. I get the feeling you set the link to your images on you computer. Attach the images as JPEG files
lchamarthi
Apr 10 2006, 06:46 AM
Hi TWControls,
Please find the attached images. In this can you please explain me the MVM instruction manipulations (source, mask, & dest).
Many Thanks
Lakshmi
TWControls
Apr 10 2006, 07:26 AM
We will use your first MVM as an example. I am going to use a value of 2#0010_0100_1010_0111_0000_0000_0000_0000 for Local:8.I.Data
For you mask 33488896 = 2#0000_0001_1111_1111_0000_0000_0000_0000 in binary
The MVM works on a binary level. If a source bit is 1 and its mask is one, it will write a 1 to the destination bit. If the source bit is 0 and the mask is one, it will write a zero to the destination. If the mask is zero, the destination will remain what it was before the instruction regardless of the source bit
Example
2#0010_0100_1010_0111_0000_0000_0000_0000 Source
2#0000_0001_1111_1111_0000_0000_0000_0000 Mask
2#0000_0000_1010_0111_0000_0000_0000_0000 Destination
Does that help?
lchamarthi
Apr 10 2006, 08:21 AM
QUOTE(TWControls @ Apr 10 2006, 07:26 AM) [snapback]31654[/snapback]
Example
Does that help?
Really I stucked up here until u gave a hand. I will be glad to find & have Mr.PLC forum & group of good helping people.If i don't know certain things also i will agree to do my boss with confidence because of forum people's help.
In this example Source is deviated from my example.
If i take these bits correctly as in my example,
2#0010_0100_0001_1101_0010_0101_1111_0110 Source
(33488896) Mask
2#0000_0000_0001_1101_0000_0000_0000_0000 Destination
Dest 11101 = which is
( 29 ) decimal
Is my manipulation is correct? If then, Dest Should have 29 decimal but in program Dest is 8388608 ?
This i couldn't get.
Also in DIV instruction,
Source A is 8388608
Source B is 65536
If i do normal division taking both as decimal 128. But in program Dest is 2. This also I confused.
Please correct/guide me in correct path.
Thanks in advance
Lchamarthi
panic mode
Apr 10 2006, 08:30 AM
mask simply specifies which bits from source are transfered to destination. if particular mask bit is zero, that bit in destination is not changed but if mask bit is one, source bit is copied into destination.
this can also be achived with combination of AND and OR instructions but it's shorter to write using MVM.
assume following:
destination BEFORE:
0011_0011_0011_0011
then we run MVM and
source is 0101_0101_0101_0101
mask is 0000_1111_0000_1111
result (destination AFTER) will be 0011_0101_0011_0101
the second instruction DIV 65536 is used instead of bit shift instruction
(Last 16-bits are removed)
lchamarthi
Apr 10 2006, 08:31 AM
QUOTE(panic mode @ Apr 10 2006, 08:24 AM) [snapback]31661[/snapback]
Oh! Ya I understood. Can anybody clarify me on DIV instruction query also so that i can move ahead?
Thank you Panic!
Regards
Lchamarthi
TWControls
Apr 10 2006, 08:46 AM
It would help if we had a bigger picture of what is going on here but I get the feeling I know what they are doing since 65536 is kind of a special divide.
Notice that your mask is only concerned with bits 16-24. This is pretty much the upper half of a double integer. The programmer was needing to pretty much move bits 16-24 to bits 0-8 for some type of manipulation or something. By dividing by 65536 it does just that
For an example 33488896 (2#0000_0001_1111_1111_0000_0000_0000_0000) divided by 65536 equals
511 (2#0000_0000_0000_0000_0000_0001_1111_1111) Note in binary it is the same value shifted 16 bits
panic mode
Apr 10 2006, 03:40 PM
imagine you deal with decimal value integers and you start with number like 12345
if you divide by 10, 100, 1000 etc., results will be
1234
123
12
1
0
it's because we divided with BASE (base in decimal is 10).
when you look at numbers in binary format, same happens when you
devide by 2,4,8,16,32 etc.
start with number like 1010111100001010
and results will be
1010111100001010
101011110000101
10101111000010
1010111100001
101011110000
10101111000
1010111100
just don't forget to add leading zeros on the left side of the number.
so someone needed to shift the binary number few places and they decided to do it with DIV...
oh, and imagine what happens or in system with base 3 if you divide by 3,9,27,81....
you can check for example in octal (divide by 8,64, 512, 4096...)
or in hex (divide by 16, 256, 4096,...)
btw. see what is binary representation of numbers 2,4,8,16,32
or hex for numbers 16, 256, 4096, 65536
etc.
any calculator should handle it.
click here.
