QUOTE(timofthedeep @ Apr 7 2006, 12:15 AM) [snapback]31441[/snapback]
What is required to pull the program out of a 2711-b6c2 panelview into panelbuilder32? Direct connection to the laptop, or it is connected to a slc5/03. Can I get the processor to pass through?
Thanks.
Yes, its possible to use the 5/03 as a passthru device, I've done it several times within this last couple of years before I got a card. For help on setting status bits see:
http://domino.automation.rockwell.com/appl...C3?OpenDocument and/or
http://domino.automation.rockwell.com/appl...AD?OpenDocument If you do a lot of PV and PV+ programming, get a compatible
Compact Flash card and PCMCIA adapter to download and upload. Works a lot cleaner.
