You guys that are having problems.
Have you tried deleting your COM1 port in your computer and letting Windows XP re-install it?
Make sure that you PIC is not connected, and that nothing is using COM1 when you do this.
Go into > Control Panel > System > > Hardware > Device Manager > Port (Com and Printer)
Right click and UNINSTALL COM1 and COM2
First take notice to what it says. Does it say (Communication port com1)? Or does it say something else?
Like (Allen Bradley Com1) Or (Modem Com1) or (US Robotics Com1) etc?
If it doesn't say (Communication port com1) then something in your computer has taken ownership of your com port, and you have to figure out what it is.
If it says Communication port com1, then UNINSTALL it.
Next right click, and click on Scan for Hardware changes. Windows XP should plug and play and re-load your Communication Port com1 driver.
Now start RS Linx, Make sure you are running 2.42 Lite at the least.
When it start, if you had the PIC driver running before, it WILL GIVE YOU A WARNING about the driver not being Windows compatible, just say OK to this question anyway. If you don't get that far, then you still haven't solved the issue.
If you didn't have the driver installed before, when you get to the Rs Linx app, DO NOT hit the browse tree on the left, this starts the driver and you CAN NOT DELETE IT. Instead, click on Communication, then Configure Drivers
Like in my article:
http://www.mrplc.com/kb/index.php?page=index_v2&id=65&c=11Try then to configure a PIC driver. Make sure you DELETE all other drivers. Just delete them all.
Even after deleteing all the drivers, try rebooting your PC once. And double check your com ports and make sure it still says: (communication port com1).
Then go back into RS Linx and create the PIC driver.
Let me know.
