Full Version: Encoder To Ab1200
andrea
Hi
I have a encoder with the descrpition on it " +5volts on the red " My question is can I hook it up to a AB 1200 1762-L24BWA and how do you hoook it to the plc
Leads ----Function
red--------- +5volts
black-------- common
white -------CH A
green-------- CH B
SHIELD------- CASE GRD
Thanks Andrea
TWControls
You can't. You need a 24VDC encoder
After that look at THIS technote A17586 - "Quick Start " Using the High Speed Counter ( HSC ) for the MicroLogix 1200 and 1500
Post the part number and manufacturer of the encoder you have if you need help changing the part number the 24VDC
andrea
Hi
Thanks for the reply .
The encoder is a MOTION CONTROL DEVICES
MODEL NO ---- C-0102-0 SIN 08850228 CUSTOMER P/N 82884
Thanks Andrea
TWControls
Not sure about that company. You may need to call them to figure out the 24 VDC equivalent
