Full Version: Connecting To A Modem
hartness
Hello,
I have a U.S. Robtic V.92 modem connected to a Micrologix 1500 LRP Series C. I want to be able to connect to the processor from at home. I have tried with rslinx but no luck, i think i am missing something, any help much apreciated.
mfkuss
We do this all the time here...download this word doc for setup instructions for RSLinx as well as for the modem... [attachmentid=2230]
hartness
Thanks for the help.
Chris Elston
I wrote a whitepaper on this. You can read it here:
http://www.mrplc.com/kb/index.php?page=index_v2&id=9&c=11
BobLfoot
The document is good but having used modems from KY to FL, KY to WA and KY to MN allow me to add a couple of points.
1. If going any distance I'd advise using no faster than 9600. Some switching untis have trouble with 19200.
2. If the PLC is set to 9600 then set your PC dialing modem to that speed as well with an AT command string prior to dialing. This will force the robotics to answer at the desired baud and avoid a lot of problems later on.
QUOTE(mfkuss @ Apr 3 2006, 02:13 PM) [snapback]31039[/snapback]
