QUOTE(TWControls @ Apr 3 2006, 09:47 AM) [snapback]31015[/snapback]
QUOTE(DLinton @ Apr 3 2006, 09:32 AM) [snapback]31014[/snapback]
Thanks, updated and opend fine.
Will work with it and see how it works. I am starting to believe it will be easier to use servos then steppers. Steppers were allready there in place so thought I would try them out.
Well I was trying to be nice, but yes, servos are much easier to use. I really didn't think there were new stepper applications. But sounds like you are doing some modifications to an existing machine
Yes, it is in a older simulation that used the steppers to control the pick and place, like a Gantry crane instead of using hooks and cables it used linear screws on steppers with pneumatic suction and rotary table to rotate. The older PLC used Statement list to program and the steppers were done by a third party so that left me where I am. I will get it for the AB SLC 500 and then into Control Logix but probably with servos.
Thanks again for your help.
I love these forums for this reason even as you may see some disagreements
among some people, they still have something to share.
