sadlerej
Feb 10 2006, 09:38 AM
I am looking for the easiest way to calculate the time difference in a slc 5/03. I would like to capture the time when a fault happens and again when the machine is restarted. After that calculate the difference in the times and place that into a register that will allow me to add to it each time the same fault happens. Thanks for any help
TWControls
Feb 10 2006, 09:44 AM
If the time between the fault and the restart will be less than 9 hours just start a TON with an Preset of 32767 and a base and 1.0 seconds when the fault occurs. Then when you see the machine restart move the TONs accumulated value to you register.
This will only work to a little over 9 hours though. 32767/3600 = roughly 9.1 hours.
If you need more time that that we will have to do a little more
sadlerej
Feb 10 2006, 09:50 AM
Thanks for your reply. I was looking at this option also but, was unsure if a rto would be better because of having to keep track of the time through out the day. I would also rest the timers through an opc connection every 8 hours.
click here.
