Full Version: Cant' Communicate With A Pv300
Mo_AB_4EVER
Hi everyone!
I am trying to communicate with a Panelview 300 micro. It is communicating with a SLC5/03 on channel 0.
The channel 0 is setup on DH485, at 19200, Node adress 1, Token hold factor 1 and max adress 31.
The part number of the PV is 2711-M3A19L1 series A rev C, Firmware 4.41.
It really looks like I need to configure RSLinx with the PIC driver.
I have tried to configure RSLinx with RS232, auto-configure, with the 1747-PIC/AIC driver, tried to use different cables, adding a null-modem, etc etc. The panelview will not show up in RSWho. ranting.gif
The funny thing is that the PV300 communicates with the PLC just fine. How can this happen?
Then I tried to communicate with another PV300 in the plant, and it runs fine. So my laptop and my cable is OK.
What is going on??
jstolaruk
This terminal uses RS232 h/w with DH485 protocol. You should be able to connect to it with your PC using the DB9 on a 1747-UIC. Or if you have the h/w (PCMK) to connect to the 5/03's RS485 port, you may be able to do a pass-thru to the terminal on channel 0.
Mo_AB_4EVER
QUOTE(jstolaruk @ Jan 31 2006, 11:23 PM) [snapback]27749[/snapback]
And how does this passthru configured in RSLinx??
jstolaruk
QUOTE(Mo_AB_4EVER @ Feb 1 2006, 03:48 PM) [snapback]27804[/snapback]
Its not. Its configure in the SLC 5/03 status tables. Follow this link to find out how:
http://domino.automation.rockwell.com/appl...2B?OpenDocument
