Full Version: RSLinx 2.43/WinXP/PIC driver..logo testing warning
gravitar
Hello! I recently jumped on the Windows XP bandwagon with my programming terminal.. For the most part everything is working fine, but I get an annoying message every time I start up RSLinx about the PIC driver not being "windows logo tested". I can tell it to continue loading anyway and it works fine, but it would be nice if I didn't have to respond to this warning every time I launch Linx. I checked the A-B knowledgebase and this forum, and didn't see anything dealing with how to make the warning go away. Surely someone has figured out how to make it go away?!
Contr_Conn
Right click om my computer, Properties, Select Hardware tab, press driver signing, select ignore.
keesoon
tri to us the 1747 UIC this is a USB to DH+ converter is like 10 compact than the pic driver and cheaper in prise
I got the same probelm before and also if you tri to use the RS232 port you need to delete the port on devise management window and re boot the PC
the AB knowledge base recommends to uninstall o unroll some drivers but this is not a good idea because doing this some how delete some of the battery drivers (on lap top)this is my personal expirense
so for my the best soluton is buy the 1747 UIC
gravitar
