Alky
Dec 12 2005, 11:02 PM
I have been working with Omron controllers for a while always with a hand held programer, have just started with a host link and SYSWIN 3.4, after installing the software on my office desktop i tried to link with the plc (C28K) hooked right up, uploaded program made changed and downloaded seveal times, i was so happy i thought i would try to get a field computer ready, (laptop) installed software and tried to link with plc got a (Communcations error " RECIEVED HEADER TOO SHORT"), hooked back up to my desktop and recieved the same error.
Can anyone help?
Thanks alot!
Jay Anthony
Dec 12 2005, 11:21 PM
Unmount the hostlink from the C28K and the re-mount it again. Then try your connection. Hostlink sounds confused.
Alky
Dec 13 2005, 12:41 AM
tried that made no difference.
thanks!!
BobB
Dec 13 2005, 06:33 AM
A long time since I used Syswin but if I remember correctly it had something to do with the communications being set up for 1:1 and should be set up for 1:N for Syswin. Set the hostlink DIP switch for 1:N communications and try again.
JouniK
Dec 13 2005, 06:54 AM
These settings have worked for my C28K and lk201 hostlink unit, though i have only tried it with syswin 3.2( if that makes any difference). I haven't changed them:
SW1:
machine no: 0
parity: even
data format: ascii
power on: program
(in other words all from SW0 are set to 0)
SW2:
baud rate 9600
SW3:
default (dip 1 =1, the rest are 0)
Alky
Dec 13 2005, 09:53 AM
Have checked all the switches every thing seems to be good, i didn't change any of them after the first time i tried to hook up and it worked, it was just after trying to get my laptop to work that i had this problem, i am working with my desktop again now and still nothing.
Thanks everyone for your help!!!
JouniK
Dec 13 2005, 10:34 AM
Weird, something must've changed between the tries. The only thing comes to mind is some sort of problem with the cable, but i don't know.
kcor
Dec 13 2005, 12:53 PM
This may not be your problem, but i have a new dell laptop, and whenever I try to use any software that uses the serial port, I have to go into the control panel-system- and reload my serial port drivers. Then everything will connect and work okay.
I am running windows 2000 on my pc.
My IT group has tried to figure out why I have to do this, but after letting them rebuild my PC a couple of times and having to reload all of the software, I just make it a habit now that everytime I try to use the serial port, I just reload the drivers for the serial port.
Alky
Dec 13 2005, 02:43 PM
Dead on with the com cable found a stray wire strand between pin 2 and 3
Once again THANKSSSSS!!!!!!
JouniK
Dec 13 2005, 03:02 PM
Heh, NP, good thing you found the cause.
click here.
