Full Version: dh485 by channel 0
Guest_Carlos
How can i configure the channel 0, to connect a slc503 with a 1747-aic (using the rs232 connector) and then a dh485 network???
because i have a problem with the adressing of the bits.
mgvol
I'm not sure what you mean by "...addressing the bits." To configure Ch. 0 of the SLC for DH-485, you must select DH-485 in the Ch. 0 configuration tab in the offline program, then download into the CPU. Then connect CH.o of the SLC to Port 1 of the AIC+ with a 1747-CP3 cable. I see now that you said you were using a 1747-AIC, and not an AIC+. As far as I know, there is no way to connect a 1747-AIC to CH.0 of a SLC; they are designed to connect to the RJ-45 connector (CH.1) on the 5/03.
