Full Version: Help! How to clear the major Fault in Ladder
xiangli
In ControlLogix5000,when useing a power-up Handle in Run Mode,controller will set Major Fault type1,how can i clear it in the handle,what instructions should be used? Thanks 8-) thumbs-up.gif
maellis
Check out "Logix5000 Common Procedures" in should be available under "Online Books" on the help menu in RSLogix5000. If you didn't install online books, you can get it from the cd or download it from the web site. It has a good explanation and step by step instructions.
But basically what you do is read the faultcodes with a GSV instruction, then zero out the fault type and fault code with a SSV instruction. The part I found somewhat confusing at first is that you use the PROGRAM object, not the CONTROLLER or CONTROLLER-DEVICE.
xiangli
