JohnC
Aug 14 2005, 06:36 AM
Ok another question
Trying to use MSG command
Getting these error messages
on node 3 : Host Has a Problem and will not Communicate error(hex)20
on node 1: Target Node Cannot Respond Because of Incorrect Command Parameters error(hex)10
JohnC
Ken Moore
Aug 14 2005, 06:38 AM
It would be easier to help if you posted your code. Then someone may be able to spot your problem right away.
JohnC
Aug 14 2005, 09:34 AM
ok here we go
Node3: Type: Peer to Peer
Read/Write : Write
Target: 500cpu
Local/Remote: Local
Control Block: N7:30
Control Length: 14
Setup:
Data Table: N7:5
Element: 1
Channel: 0
Target:
Timeout: 0
Data Table Addr: N7:5
Local Node Addr: 1 octal 1
Node1: Type: Peer to Peer
Read/Write : Write
Target: 500cpu
Local/Remote: Local
Control Length: 14
Setup:
Data Table: N7:5
Element: 1
Channel: 0
Target:
Timeout: 5
Local Node Addr: 3 octal 3
Error message Target does not respond
JohnC
TechJunki
Aug 14 2005, 10:45 AM
Are you sending this over DH+ or what type of communications are you attempting to send over.
If you are using DH+ I believe you will need Channel 1 not 0, if I remember correctly Channel 0 is for the serial port.
Aug 15 2005, 01:27 AM
hi yes using general channel 1 dh+
JohnC
Ghettofreeryder
Aug 15 2005, 01:59 AM
If i were you, i would set up the message blocks so one plc initiates all the communication. Otherwise, your just asking for trouble over dh+. Id set up one plc to do both a read and a write, and the other with no msg blocks(master/slave system). We are overhuling a plant right now because of this reason. One of the plcs constantly times out, so we are moving all the logic to one plc and installing an rio adapter.
TechJunki
Aug 15 2005, 05:37 PM
| QUOTE (Guest @ Aug 15 2005, 01:27 AM) |
JohnC |
Then why in your setup have you selected Channel 0 ????
Read/Write : Write
Target: 500cpu
Local/Remote: Local
Control Length: 14
Setup:
Data Table: N7:5
Element: 1
Channel: 0Target:
Timeout: 0
click here.
