im trying to get 3 servo motors to spin a 360 with variable increment angle to 1 degree accuracy. the accuracy is compulsary to be 1degree.
In simple words, moving motor from 0deg to 60deg in 1deg increment and then from 61deg to 120deg in 3deg increment and there onwards do up to 360deg with 5deg increment.
The increment can be in any order, the above is just an example, but the minimum increment input is 1 degree. and fractional increments are not wanted i.e motor does not need to swing in half or quarters.
im using micrologix 1500 plc, with RS logix 500 and Rslinx.
i cnt get the motor to do multi increments, it starts at 0, does 5deg increments al the way to 360..
can somebody help?
thanks
