Sounds like a DDE "Cold" Link would better suit you. I would write a VBA script in Excel to get your data via a timed event and COLD DDE calls.
Download this sample file, look at the VBA script code by viewing the Macro editor.
http://www.mrplc.com/dl/index.php?action=v...ntry&entryid=74A cold DDE link looks like this:
| CODE |
'opens a COLD DDE link RSIchan = DDEInitiate("RSLinx", "M1138") 'read word F8:10 and load into a VB variant variable f810data = DDERequest(RSIchan, "F8:10") 'read word F8:11 and load into a VB variant variable f811data = DDERequest(RSIchan, "F8:11") 'read word F8:12 and load into a VB variant variable f812data = DDERequest(RSIchan, "F8:12") 'read word F8:16 and load into a VB variant variable f816data = DDERequest(RSIchan, "F8:16") 'read word F8:18 and load into a VB variant variable f818data = DDERequest(RSIchan, "F8:18") 'read word F8:17 and load into a VB variant variable f817data = DDERequest(RSIchan, "F8:17") 'read word F8:20 force check #1 and load into a VB variant variable f820data = DDERequest(RSIchan, "F8:20") 'read word F8:21 force check #2 and load into a VB variant variable f821data = DDERequest(RSIchan, "F8:21") 'read word F8:22 force check #3 and load into a VB variant variable f822data = DDERequest(RSIchan, "F8:22") 'read word F8:23 force check #4 and load into a VB variant variable f823data = DDERequest(RSIchan, "F8:23") 'read word F8:24 max force and load into a VB variant variable f824data = DDERequest(RSIchan, "F8:24") 'read word F8:25, get PASS or FAIL status from PLC and load into a VB variant variable varResults = DDERequest(RSIchan, "F8:25") 'close COLD DDE link DDETerminate (RSIchan) 'write all values to cells Cells(lngRow, 1).Value = f810data Cells(lngRow, 2).Value = f811data Cells(lngRow, 3).Value = f812data Cells(lngRow, 4).Value = f816data Cells(lngRow, 5).Value = f818data Cells(lngRow, 6).Value = f817data Cells(lngRow, 7).Value = f820data Cells(lngRow, 8).Value = f821data Cells(lngRow, 9).Value = f822data Cells(lngRow, 10).Value = f823data Cells(lngRow, 11).Value = f824data
Hope that helps.
