Jack
Feb 27 2003, 01:56 PM
[FONT=Arial][COLOR=purple]can anyone tell me what the cable layout is, for programming Allen-bradley PLC's.
I want to try the software from the web and make a backup from the plc-programm that is allready running.
Guest_MAD
Feb 27 2003, 10:05 PM
What PLC are you using??? SLC 500???
panic mode
Feb 28 2003, 01:47 AM
The cable pinouts can be found in documentation on AB website.
If you are using SLC500 series PLCs, ControlLogix or compact logix,
the simple crossover will do:
DB9F------DB9F
2-------------3
3-------------2
5-------------5
Original AB cable is little bit more complicated but this one definitely
works. In case you are using micrologix, save yourself some time and
just buy it (should be ca $30).
regards,
panic mode
