I am trying to create a df1 RS232 drive to communicate with AB PLC 5 using Visual basic 6 after weeks of searching the only thing that I found to get me and starter is this code from this forum
control.comI have made some modification but I am not able to make it work I know that the ConvertFileType function is missing I contact the author of the code but did not received and answer yet
What really got me lost is the creation of the command to send (QueryBuffer)
I was reading the AB DF1 Protocol but I can not figure it out
If some body has some code to get me started please email it to hidroela@msn.com
Any help would be appreciated
Best regard Hidroilio Perez
| CODE |
Dim DestinationNode As Integer Dim SourceNode As Integer Dim TransactionNo As Integer Dim Size As Integer Dim FileNumber As Integer Dim FileType As Integer Dim ElementNumber As Integer Dim SubElementNumber As Integer Dim TimeOut As Integer
Public Function MsgCRC(Message As String) As String
'Calculate CRC checksum for message then add 'to end of message. Check for 10h byte 'DLE' 'within message and change to 'DLE DLE'.
'Function to calculate message CRC
Dim xByte As Integer Dim xResult As Long
xByte = 3
Do
xResult = xResult Xor Asc(Mid(Message, xByte, 1))
RotateResult xResult 'test for 'DLE' and double up to DLE DLE
If Asc(Mid(Message, xByte, 1)) = 16 Then
'add extra DLE Message = Left$(Message, xByte) + Chr(16) + Right$(Message, Len(Message) - xByte)
xByte = xByte + 1 'don't include in CRC
End If
xByte = xByte + 1
Loop While (xByte <= Len(Message) - 2)
xResult = xResult Xor 3 'ETX byte RotateResult xResult
'add CRC checksum to message MsgCRC = Chr(xResult Mod 256) + Chr(Int(xResult / 256))
End Function
Public Sub RotateResult(res&)
Dim bitout%, shift%
'Rotate result 8 times and combine with const.
For shift% = 1 To 8
bitout% = res& Mod 2 'test if bit will be shifted out res& = Int(res& / 2) 'shift right
If bitout% Then
res& = res& Xor &H1000A001 'xor with constant res& = res& - &H10000000 'clear top word
End If
Next shift%
End Sub
Private Sub Form_Load()
RS232PLC.CommPort = 1 ' 9600 baud, no parity, 8 data, and 1 stop bit. RS232PLC.Settings = "19200,N,8,1" ' Tell the control to read entire buffer when Input ' is used. RS232PLC.InputLen = 0 ' Open the port. RS232PLC.PortOpen = True DestinationNode = 0 SourceNode = 0 TransactionNo = 5 Size = 4 FileNumber = 0 FileType = 7 ElementNumber = 31 SubElementNumber = 14
End Sub
Private Sub Timer1_Timer()
Dim TmpTime As Date Dim QueryBuffer As String '2:Clear MsComms Buffer RS232PLC.InputLen = 0 QueryBuffer = RS232PLC.Input
''3:Create Query (Build the string) QueryBuffer = Chr$(16) & Chr$(2) & Chr$(DestinationNode) & _ Chr$(SourceNode) & Chr$(15) & Chr$(0) & _ Chr$(TransactionNo) & Chr$(0) & Chr$(162) & _ Chr$(Size * 2) & Chr$(FileNumber) & _ Chr$(FileType + 132) & _ Chr$(ElementNumber) & Chr$(SubElementNumber) & _ Chr$(16) & Chr$(3)
'4:Calculate Crc Check Sum and add to Query QueryBuffer = QueryBuffer & MsgCRC(QueryBuffer)
'5: Send Message
RS232PLC.Output = QueryBuffer
'5:Wait for acknowledgment Or Time Out TmpTime = Now
Do
DoEvents If DateDiff("s", TmpTime, Now) >= 3 And _ RS232PLC.InBufferCount < 2 Then
Exit Do
End If
Loop
'6:Remove acknowledgment from buffer RS232PLC.InputLen = 2 QueryBuffer = RS232PLC.Input
'7:Check for good acknowledgement
If QueryBuffer <> Chr(16) + Chr(6) Then
MsgBox "Bad Ack" Exit Sub
End If
'8: Wait for response
TmpTime = Now
Do
DoEvents If DateDiff("s", TmpTime, Now) >= 3 And _ RS232PLC.InBufferCount < 12 + (Size * 2) Then
Exit Do
End If
Loop
'9:If timeout then exit
If RS232PLC.InBufferCount < 12 + (Size * 2) Then
MsgBox "Timed Out" Exit Sub
End If
'10: Send acknowledgment RS232PLC.Output = Chr(16) + Chr(6)
'11:Get response RS232PLC.InputLen = 0 QueryBuffer = RS232PLC.Input
'12: Remove surplus 'DLE's TmpTime = 3
Do
If Mid(QueryBuffer, TmpTime, 1) = Chr(16) Then
QueryBuffer = Left(QueryBuffer, TmpTime) + Right(QueryBuffer, Len(QueryBuffer) - 1 - TmpTime)
End If
TmpTime = TmpTime + 1
Loop While TmpTime < Len(QueryBuffer) - 4
End Sub
Public Sub ConvertFileType(FileType As Integer)
End Sub
