I am trying to read the fault parameter from a 160 drive that is on DeviceNet talking to a PLC5 so I can display which fault has occurred on the PanelView. The only way I can see to do this is to use explicit messaging. Is there another way? If not will the set-up I have come up with work?
I have attached a RSLogix5 file with my programming in it. I can't try this right now because the processor that I need to put it in doesn't have enough memory and they are going to have to change it out but I may have to use this when they do.
I basically used the example program in the manual for the 160 Device Net module (160-DN2) and modified it to read different nodes as they fault. The setup file for the messaging is to be moved to the block transfer word when a fault occurs. the different setups are stored in N84. The Block Transfer word is N83.
The nodes are 11, 12, 13.
The parameter I want to read is 7
the rest of the info in N84 are the remaining things needed to format the explicit messages.
I have never tried this before so I hope someone can help me out. Any help would be greatly appreciated.
