Full Version: RSVIEW32 problem
nileshsurya
hi thr all ppl
good morning
i have come across a very stupid problem,hope i will get the answer for it in this forum
my RSview32 has gone corrupted. when i open a project ,it is loaded 50% and at the time of database synchronization it gives me Realtime data manger error and then aborts project loading
i have tried uninstalling RSVIEW and then reinstalling again but it was waste
i have also tried installing to a higher version but tht also didnt work
i have one option to format the hard disk and reload everything again from scratch,but i dont want to do that.
is anybody there who has come across similar problem and have got a solution?
plz tell me i will be very thankful
i use RSVIEW32 version 6.5 and also tried upgrading it to RSVIEW32 7.10 (cpr 6)
but this didnt work
plz help me out
thanx in advance
Regards
NileshSURYAb
OkiePC
Sounds like your project is corrupted, not RSView. Try opening another project that's known to be good. If you don't have a backup, you may have to recreate parts of it from scratch. You should be able to import parts of your old project bit by bit until the problem occurs. I don't have RSView in front of me right now, but if you look at how the project is stored on the hard drive, it's separated into several folders. You can create a new project and save it, then copy stuff from the corrupt project into the new one. Each time you copy something, open the project to make sure it's not corrupt. From your description, it sound like the tag database is corrupted. You may be able to delete just those files and then recreate only the tag database. Also, there are literally hundreds of tech notes on ab.com concerning RSView. Some of them may offer assistance with your problem
I've had a strange problem with an OEM project that got really strange when we tried to upgrade v7.10. My advice is don't upgrade until you've gotten your project fixed.
Good Luck!
Gerry
Try exporting the database using the import/export utility and then re-import. The export will give you three CSV files that you can examine using EXCEL.
Snerkel
The RSview cache can become corrupt. It is worth deleting the cache and see if it works.
To prevent problem we had re-occuring I wrote a utility to delete the cache, then start RSview. If it would be useful you can download it here http://www.tech24.co.uk/download/rsviewD.zip
johnboy
You might also want to check the properties for all of the folders in your Project to make sure that they are not set to "Read Only". This could happen if the project was backed up and/or reloaded onto a disk.
