Hi,
I'm new so bare with me if I do something wrong here. Well the problem, I hooked up a micrologix 1000 to switch a lathe between forward and reverse. The lathe started out a 3 phase 7hp motor which was switched to a 240 single phase 7hp motor.
It works fine most of the time but I'm not sure if when I stop or start the motor sometimes the processor will fault with a major error 8h "A fatal internal software error occurred."
The plc is mounted in the same panel as the motor starter relays and 240ac input lines. Seems to be caused from inconsistant ac supply to the plc when lathe is stopped or started.
What do you guys think my problem is, like I said I think it is happening when lathe is stopped because I don't hear the motor relays try to start when it happens but works fine until the stop switch is pushed.
The controller is a 1761-L16BWA
Thanks in advance,
Tom
