trn_psycho
Mar 16 2005, 11:47 AM
Anyone ever ran into this problem: And have a fix for it?
"Panelview 1400E Problem - Error in Synchronizing Channel 1.
Cause: Network Type 'Remote I/O' not installed."
Ken Moore
Mar 16 2005, 11:52 AM
Couple of questions:
1. Exactly which model of 1400e do you have?
2. Is this a new application or an existing one?
I have a hunch , and the answer to #2 will help.
KEn
trn_psycho
Mar 16 2005, 11:54 AM
It's an older application. I just downloaded it from the machine earlier today (Last night for me).
I'm running Panelbuilder 1400e v5.15
trn_psycho
Mar 16 2005, 12:48 PM
I was able to open the file on a different machine at work. When I first tried to open it on my laptop, it gave some other error that I don't remember right now. This turned out to be because I didn't have the latest service pack from MS (I'm running XP Pro). WELL... After installing this, is when I get the prior mentioned error...
PS: Ken, are you using a cgi to create your sign image?
Ken Moore
Mar 16 2005, 12:57 PM
Did you download if from one panel view and then load it on to another?
Sounds like the first one used RIO, and the 2nd one uses DH+ or something else.
Ken
trn_psycho
Mar 16 2005, 01:00 PM
No... I downloaded it to my harddrive. Then opened it to see if it worked. It did. I then copied it to a usb pen drive so that I could move it over to my other laptop. When trying to open it on the second machine is when I started getting the problems. I thought it might have something to do with the download process, so I took my other laptop out to the machine and downloaded the program onto it from the PV. When I tried to open it to verify the file, I got the error I described.
Ken Moore
Mar 16 2005, 01:11 PM
Got the sign from www.danasoft.com
Well that shoots down my theory, maybe someone else has encountered this problem.
I've only dealt with the 1400e on a limited basis. I would not recommend them for future applications.
trn_psycho
Mar 16 2005, 01:17 PM
I didn't pick the panel... I'd upgrade it if I could, but to be honest, I'm not sure what kind of mess I'd be getting into there. That's the main reason I was downloading the program, so I could see how big of a pain it was. (This is the first time I've ever messed with a PV1400...)
TechJunki
Mar 16 2005, 02:33 PM
trn_psycho
Mar 17 2005, 12:46 AM
OK, I'm working now. Here's the deal as far as I can tell.
FIrst, I downloaded the program from the panelview to my computer. I couldn't open it because I had service pack 1 installed for windows XP. (This is a documented problem.) What's the fix? Install service pack 2 or contact MS for the hotfix. Well, I was in a hurry so I installed SP2.
Installing SP2 overwrote some of the settings in windows that asigns what files are opened by what program. (This resulted in the remote I/O errors).
The next step was nothing more than do a re-install of panelbuilder 1400e so that windows would not asign certain files to IE6.
From there, I was able to open the file with no problems what so ever.
PS: Thanks everyone for the help...
Ken Moore
Mar 17 2005, 05:28 AM
Glad to hear that you resolved your problem.
Sorry I couldn't be of more help. But I knew someone here could help you out.
click here.
