sparky
Feb 24 2005, 05:18 PM
Greetings, I understand there is software for programming a SLC 150, instead of using handheld programmer. If so what is it called and, is it very costly,do I need special cable?
Thankyou
Sparky
mgvol
Feb 25 2005, 08:06 AM
The software was 9311-SL25D; the interface converter was 1745-PCC. The bad news is the SLC 100/150 line has been obsolete for years. If your lucky, your AB distributor will have this stuff lying around and may let you borrow it. Then you have to find a laptop that will run the old DOS software. You could also try e-bay.
controlfreak810
Feb 25 2005, 11:34 PM
Sparky,
Try this link for the software-
http://www.software.rockwell.com/support/download/There are 2 disks for download titled slc150 disk1 and slc150 disk2. They are about half way down on the page if you don't limit your search. I have downloaded both disks, but have not been able to run them. Still looking for a DOS work around!!
Good luck--
danatech
Feb 26 2005, 06:18 AM
i actually have this software on an old compaq 486 laptop that we keep around for one application in our plant that has a slc 150 in it. you can pick up these old laptops pretty cheap, if you do some checking around in your area.
darrenj
Feb 26 2005, 07:58 PM
check a local collage or tech school..thats where i borrowed mine from..The software is easy..its the interface that gets hard to find!!
sparky
Feb 28 2005, 09:00 AM
Thanks guys
Sparky
click here.
