Full Version: PLC KOYO CPU SA-21. upload software
Forums.MrPLC.com > PLCs and Supporting Devices > Other PLCs
HoaiThi
Hi all !
I have a machine use PLC KoYo KOSTAC CPU SA-21
It is so old and I can't find anything about it.
I want to know which software can upload program for it
Thanks a lot.
Regards,
Hoai Thi
HoaiThi
Hi, all !
Any Body help me that subject :PLC KoYo KOSTAC CPU SA-21. upload, download software
Thanks you.
b_carlton
The web site at Host Engineering says that the DirectSoft package can program the SA-21. They also refer to it with AutomationDirect's number of D3-330P. I would contact the people at AutomationDirect
HoaiThi
Hi all !
I attach file image here. Please help find order serial: Console or capable and PLC software can connect PC with PLC : KoYo KOSTAC CPU SA-21. And I can upload, download program (not design program, only up and down).
Where I can buy it.
It urgents.
Thanks a lots.
Hoai Thi
Crossbow
As was just stated above... you should be able to use Automation Direct's software for this PLC.
Go to www.automationdirect.com and look for DirectSoft32.
HoaiThi
Thanks Crossbow !
Which capable (order number) to connect PLC with PC ?
\*D3-DSCBL-2 : PC PGMING CABLE 330/330P/ 350 DL405 BTM PORT
\*D3-232-DCU : RS232C DATA COMMUNICATIONS UNIT
I must use 2 products for its ?
see you !
Hoai THi
Crossbow
My guess would be you only need the first cable you mentioned, but I am not familiar with the old Koyo PLCs to be sure. Might want to try to submit a question to Automation Direct's technical support staff and see if anyone there remembers these older PLCs.
HoaiThi
THANK YOU Crossbow !
I'LL CHECK ITS.
HOAI THI
Yedi Seiadi reregister
you need this modul
