Full Version: RSLogix5 ver 5.00.00 installation on XP
Guest_James
Hi all,
I have a problem with RSLogix 5 version 5.00.00 will not install on Windows XP. If I try to install RSLogix 5 v5.00.00 in XP, I will get an error that I need
Service Pack 4 or higher to continue.
How to solve this problem?
Thank you
James
mgvol
Rockwell does not support RSLogix 5 with Windows XP below Version 5.20.10. You probably need to upgrade your RSLogix 5.
Firetubes
Right click on the setup.exe, select property, under the compatibility tab, check the box for "Run this program in compatibility mode for" and select Windows NT 4.0 or maybe Windows 2000. Should work.
