Full Version: Panel View writes to PLC after download
Scott Foster
I working with some new Panel View 1000G's, Panel Builder 32 (also new) and some PLC 5's.
After I download the application (over DH+) to a panel it writes the initial values in the push buttons and numeric entry objects to the PLC. This causes a very undersirable interruption in the plant processes. I tried deleting the intial values but this does not seem to be possible. I don't understand the purpose of writing to the PLC's. I would perfer that the Panel View read the current value from the PLC and did not write to the PLC without the operator using the screen.
Does anyone have a solution to this problem?
Chris Elston
I think what you will want to do is uncheck the option to write to controller on power up. Check out the screen shot.
See if that helps.
Scott Foster
Exactly what I needed. Thank you very much!!
Chris Elston
Glad we could help.
