Have an rj3ib controller and when I power up the robot the i/o (for example Robot in auto bit to PLC) flashes on and off on PLC screen. This happens with all i/o on hot start.Is there a place in system variables or somewhere else that I can stop this? It seems to be a controller test on bootup.
The original problem is that I have 12 robots in one station welding a vehicle(spotwelding), If I have a problem I power down robots to repair. I power up the controllers and the robots crash (pounce to weld but do not run program they should be running). Program selection is through PLC( allen bradley I/O through data highway). PLC program is solid. I can't figure out the problem, i just noticed that the I/O flashes on and off on robot boot. This may be why program selection is wrong.
thnx
